Power Window works.... sometimes. Bad relay?
Old Oct 4, 2008 | 08:45 AM
plasmeh's Avatar
Car: 1986 IROC-Z
Engine: 360cu @ 10.5:1
Transmission: T56 - Pro 5.0
Axle/Gears: 4.10 - Zexel Torsen - Moser Axles
Is there a relay that controls the power windows in an 86 IROC? I know there is a relay in the center console, not sure what that's for though. Both my trunk release and power window switches only work intermittently now, and it's getting progressively worse. I can only assume that would be something to do with a relay. Any ideas on how to fix this?
Old Oct 4, 2008 | 04:52 PM
plasmeh's Avatar
Car: 1986 IROC-Z
Re: Power Window works.... sometimes. Bad relay?
Could really use some help on this. I am at a loss and don't want to spend any money that I don't have to. Would like to get these fixed this weekend. Any help is greatly appreciated!
Old Oct 4, 2008 | 05:29 PM
ringo234's Avatar
Car: 89 IROC Z28
Engine: 357 TPI
Axle/Gears: 3.42 Posi
The relay in the center console is for the rear hatchback.
I'm not sure where the window relays are though.
Old Oct 4, 2008 | 06:32 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
There is no relay on the power windows that I know of. The window motors have built in resettable fuse like thing - if they don't work properly, the motors will shut down before they burn up, and you have to wait a few minutes before attempting it again.
Sounds to me like it's time for new window motors. Search for the post about window motor install being CRAP - it shows how to drill in teh door panels to remove the old motor and replace without having to remove the window regulator, which was alot easier to do when I did mine.
BRoss99
Aug 10, 2025 05:08 PM
Vintageracer
Jan 10, 2020 05:33 PM
neekolzun
Aug 24, 2015 04:59 PM
stalkier
Aug 21, 2015 01:54 AM
Dialed_In
Aug 20, 2015 01:45 PM
