HELPFUL SUGGESTION !!!
Old Oct 14, 2008 | 06:40 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
o.k. i have a chore in front of me . trying to repair hacked wires on my 88 s/c . while doing some solder work it came to me that some out there might not know of this product . it's called liquid tape . it is easy to use , better than heat shrink ( i think ) . seals very complete . just follow instuctions on container . used this stuff a lot when when i lived in fla. keys keeping my boat running . should be available at most marine supply stores . it may take a couple of coats to fully seal . DO NOT , use around carpet unless you protect it . check it out , i think you will like it . has worked for me , one small can will last a lifetime ( unless you leave it un-capped ) . good luck .
Old Oct 18, 2008 | 02:11 PM
yeah low's Avatar
Re: HELPFUL SUGGESTION !!!
Also currently available at O'Reilly auto parts in the electrical Isle at the bottom of the peg hooks, approximately midway down, according to most plan-o-grams... Hope this helps find it more easily.
Old Oct 18, 2008 | 04:56 PM
UNCLE TOM's Avatar
good deal . i have not looked for any as i am still on my first can after 5 years . it is good stuff .
Old Oct 22, 2008 | 03:12 PM
yeah low's Avatar
Oh yes, much agreed, much agreed. It also works pretty well as a handle coating for small tools and pliers if anyone has the time to allow it to dry before using...
Old Oct 25, 2008 | 11:42 PM
Daves03's Avatar
Car: 1991 Chevrolet Camaro RS Red
Engine: 305 V8 TBI
Transmission: TH-700R4
they carry that at advance auto and autozone here stuff works wonders.
jklein337
Sep 19, 2018 06:23 PM
backtothe80s
Sep 5, 2015 12:39 AM
transamgta1Khp
Aug 17, 2015 12:18 PM
sreZ28
Aug 14, 2015 07:48 PM
mizz0313
Aug 12, 2015 06:45 AM
