Parking lights
Old Oct 20, 2008 | 01:30 AM
pgh1992's Avatar
Car: '92 Camaro
Parking lights
My marker lights, tail lights, license plate lights, or dash lights won’t work. I can’t figure it out, and the fuse keeps blowing. I checked all the lights and connections and they are good. Head lights still work and the brake lights come on when you step on the break. I even changed the headlight ****, and they still won’t work.
Old Oct 20, 2008 | 05:17 AM
alicat's Avatar
Car: 1985 z28 camaro
Engine: 305 lg4,edelbrock,3"air cleaner.k&n
Transmission: turbo 700r4 w/b&m megashifter
Axle/Gears: Stock.
Re: Parking lights
If the fuse keeps blowing,then it would seem you have a short somewhere in the wiring.Time for some troubleshooting.
Old Oct 24, 2008 | 06:22 PM
pgh1992's Avatar
Car: '92 Camaro
Re: Parking lights
so youthink i should just start from the front and look over all the wires? I mean i dont even know where to start with somethig like that
Old Oct 24, 2008 | 11:13 PM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Re: Parking lights
It's not uncommon for a light bulb or socket to build up corrosion and cause a short in the light circuit, especially if you live up north. It won't take long to check all the bulbs. Yes, it's a pain but it's a start.
Did the short start happening all of a sudden? What was being done to the car just prior? Maybe a wire got nicked/cut?
Lou
Old Oct 27, 2008 | 01:37 AM
pgh1992's Avatar
Car: '92 Camaro
Re: Parking lights
it happend right after i changed the head lights
Old Oct 27, 2008 | 09:25 AM
BigBadLou's Avatar
Engine: TPI
Re: Parking lights
I would be investigating the headlight harness in the engine bay, then. Sounds like there might be a short in there.
The headlight harness is separate on the C100 (the main firewall connector). You can unplug it for example, put a fuse in and see if it blows again. That'll give you an idea.
Hope this helps.
Lou
LittleFranks
Sep 17, 2015 12:22 PM
Jk_Under
Sep 2, 2015 10:59 PM
tnrednneck
Aug 13, 2015 08:57 AM
Omega
Aug 10, 2015 12:46 PM
NBrehm
Exterior Parts for Sale
Aug 5, 2015 08:19 PM
