HELP!!!!
Old Oct 23, 2008 | 04:37 PM
HiDurationIroc's Avatar
HELP!!!!
I have a 90' Camaro 350 TBI, 5-speed. I am trying to install an Autometer 5'' tach. Which wire is the tach signal wire? It is a externally mounted coil. It looks like a HEI coil but is mounted on the intake. It has two connecting blocks that run to it, with two wires per block. A pink wire, and a white wire. One set of wires runs to the distributor and the others run somewhere else. I know what all the wires on the tach go to. If you can help id appreciate it!!!
HiDurationIroc 90' Iroc 350 TBI 5-speed with a badass cam
Old Oct 23, 2008 | 07:03 PM
jermdm's Avatar
Car: 1989 Iroc-z
Transmission: Auto 700R4
Axle/Gears: 9 bolt - 2.77
Re: HELP!!!!
Tach wire should be the white wire.
