Firebird tach?No good search results
Old Oct 24, 2008 | 10:21 PM
dwillis's Avatar
Car: 1991 Trans Am Convertible
Axle/Gears: 3:08
I've searched on this to my wits end...there is a fix for the camaro tach on the site but what about the Firebird tachs?My tach is reading low,I have a 1991 TPI 305,T-5 Trans Am.....I have a v-6 tach laying around and wonder is there a way to maby change out a chip on it to work with a V-8?Or is there a simple resistor swap like on the Camaros?Thanks for any help...Dave
Old Oct 25, 2008 | 02:40 PM
dwillis's Avatar
Axle/Gears: 3:08
Re: Firebird tach?No good search results
No one has any insight on this?if I'm not searching correctly let me know but I haven't found anything on this..Thanks
Old Aug 16, 2013 | 10:23 PM
dwillis's Avatar
Axle/Gears: 3:08
TTT 5 years later and I still cant find anything!
Old Aug 18, 2013 | 07:52 PM
zenish's Avatar
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
did you go all the way through the camaro tach article to see if anyone had tryed it on a firebird tach?they may be the same inside.
Old Aug 18, 2013 | 08:19 PM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Unless you are the original owner & know that everything is 100% original & correct.....Then it would be very possible that the rear end has been replaced & does not have the correct gears (same as original) throwing the reading off. Or for the same reason.....The tranny has been replaced & has different gauge gears in it.
Ghettobird52
Jul 5, 2024 11:18 PM
Ikes 91Z
Dec 9, 2015 03:49 PM
Juneb1022
Firebirds Wanted
Oct 12, 2015 08:12 PM
mustangman65_79
Aug 7, 2015 09:41 PM
stalkier
Aug 7, 2015 04:49 AM
