Wiring Harnesses
Old Oct 30, 2008 | 03:52 PM
89RScamarotops's Avatar
Wiring Harnesses
Can anyone tell me the difference between a camaro and a T'A wiring harness? I know there are seperate ones for a TBI and TPI. I am curious to know if a t/a will work on a camaro and will control everything on the cluster inside?
Old Oct 30, 2008 | 06:15 PM
TIMMYS89GTA's Avatar
Car: 81z-28,89gta,91z-28 03 1500
Engine: 355,L98vette tpi,327
Transmission: TH350/700R4/700r4/4l80E
Axle/Gears: 3;73/3;27/2;73/3;73
Re: Wiring Harnesses
are you talking about the engine harness?
If so,should work as long as its not for a digital dash t/a.Other than that,battery is on opposite sides and requires some modification.
Old Oct 30, 2008 | 06:33 PM
vette9190's Avatar
Car: 1991 Chevy Camaro RS
Transmission: 700R4,
Axle/Gears: 3.73 w/SLP Zexel Torsen Limited Sli
My tpi setup and harness cam out of a 90 bird. I have a 91 rs. It will work may be some minor pinout changes depending on year. to the IP plug. its the one that goes from the ecm to the gauge cluster. I think its called c207. I don't know if anything else is different bc I had to rebuild c100 bulkhead as my harness was missing it, so I used the tbi harness c100 connector.
Check www.austinthirdgen.org I think or something like that. They have diagrams for almost all the different engines packages available for our cars on the site.
Old Oct 31, 2008 | 08:07 AM
what about the harness that connects to the connection block under the hood that goes into the car by the brake booster? any differences?
Old Nov 3, 2008 | 08:04 AM
vette9190's Avatar
Thats the c100 bulkhead connector I mention above.
You can find the pinouts for that connector on the website I gave above as well
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
TheJoeY88
Dec 31, 2016 07:30 PM
stalkier
Dec 6, 2015 11:25 PM
g.l.mos
Aug 22, 2015 12:02 AM
stalkier
Aug 21, 2015 01:54 AM
