Auxillary lighting?
Old Nov 7, 2008 | 09:44 AM
11ellswray's Avatar
Car: 1986 Camaro Z28
Engine: 385" SBC
Transmission: built out 700r4
Axle/Gears: 4th gen, 373, LSD, GIRDLE
Auxillary lighting?
I want to wire interior accent neon, and underglown neon as well as driving lights. How do I wire these so that I can shut them off individually and adjust the brightness of the interior neon by using the factory gauge dimming switch? And does anybody know if there is a company that sells a product that would make the job easier?
Old Nov 8, 2008 | 05:10 AM
HCR13's Avatar
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
Re: Auxillary lighting?
to my knowledge there isn't a company that makes such kits for our cars. You would have to make everything custom. Now you want to add interior neons and have them dim with the factory dimmer? Why not just add an on and off switch since the factory dimmer will dim EVERYTHING inside. I have many interior lights, but I went with LEDs instead of neon since they use extremly little power and are just as bright. I also have LEDs in the exterior wheel wells...
Old Nov 8, 2008 | 04:18 PM
11ellswray's Avatar
Engine: 385" SBC
wow i never even thought of LEDS, are they expensive(in relation to neon) and if i wanted interior, trunk, and under body lights would i need another alternator.
Old Nov 8, 2008 | 07:06 PM
HCR13's Avatar
Car: 1987 Trans Am
no, no, and no. LEDs are much cheaper, easier to work with, and use insanely little electricity. LEDs will not drain your battery unless you left it on for about 1,000 years. No joke. I mainly buy my LEDs from ebay, there are different prices. I have hooked up to my subs aswell that blink/pulse with the music...
Old Nov 8, 2008 | 07:11 PM
Stephen's Avatar
Car: 87 GTA
And neon is ON or OFF, not dimmable, so.......
Old Nov 30, 2008 | 07:32 PM
11ellswray's Avatar
Engine: 385" SBC
thanks that's very useful.
TrevinE
Sep 14, 2015 03:20 PM
florida_gators
Exterior Parts Wanted
Sep 7, 2015 07:19 PM
flash2042
Interior Parts Wanted
Sep 7, 2015 07:15 PM
luvofjah
Sep 3, 2015 07:08 PM
