just a 2 questions
Old Nov 12, 2008 | 11:21 AM
HottestZ28's Avatar
just a 2 questions
Ok now I did a 350 swap in my v6 87 camaro. I noticed that when ever the tach wire was disconnected from the hei the gauge was within reason, then when you hook up the tack wire (aftermarket tach) the gauge would show way past full. I found a loose connection for the tack wire and fixed it, made the gauge go to alittle below empty(thought it was still broken) I then ran out of gas tinkering last saturday(so it must have been acurate). I went and got 5 gallons of gas and only went to about 1/4 tank? Then started the car and within 30 secs the gauge went way past full again. Any thoughs
The gauge worked perfectly before the swap also.
2.what is the larger purple wire going from the dash towards the rear along the drivers side sill?
Old Nov 12, 2008 | 11:32 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Re: just a 2 questions
You need a V8 tach, the V6 one will read high since it's expecting 6 pulses per distributor revolution instead of 8. You can either swap out the whole gauge cluster from a V8 car, or just swap the tach - it's pretty easy to take apart and change.
Not sure about the fuel gauge question though.
Old Nov 12, 2008 | 01:07 PM
HottestZ28's Avatar
its a sun pro tach not linked nor wired into the factory tach
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
