turn signal fuse keeps blowing
Old Nov 15, 2008 | 09:16 AM
TOM305T/A's Avatar
Car: 1987 GTA 350 auto
GM recently changed steering column. now turn signal fuse keeps blowing every time i turn the key forward, i disco turn signal switch from steering column and fuse still blows when key is forward, i used old turn signal switch, it still blows. i checked wiring under dash, it looks good, i disconnected all connections from steering column and kinda crank it from the ignition switch. it still blew the fuse. any help would be great. this is for a 1985 z28, 5.o carb
Old Nov 15, 2008 | 02:05 PM
snflupigus's Avatar
Car: 92 RS, 02 Tacoma, 2 73 Porsche 914s
Re: turn signal fuse keeps blowing
wow. something is wired wrong. did they just throw a new column in or what... more background info needed.
Old Nov 15, 2008 | 03:43 PM
TOM305T/A's Avatar
yes a new column was put in, i went from a non tilt to a tilt but even with the the turn signal disco from the steering column or if i plug in the old turn signal switch, the turn signal fuse still blows
Old Nov 16, 2008 | 02:01 AM
drknow90rs_ss@y's Avatar
Car: 86 IROC-Z, '71 RS
Engine: 305 TPI/ 350
Transmission: 700R4/TH350
Wow! The fuse blows as soon as you turn the key? You need to carefully check the long plug on top of the steering column and make sure the colors match up with the old plug. The colors should all match up.
Old Nov 16, 2008 | 06:56 AM
TOM305T/A's Avatar
i checked wires everything matches, it also happens when t/s switch is disconnected
Old Dec 8, 2008 | 11:29 AM
TOM305T/A's Avatar
Im still having this problem, someone told me that i can install some type of circuit breaker, has anyone heard of that?
Ghettobird52
Jul 5, 2024 11:18 PM
Fronzizzle
Mar 18, 2019 08:29 PM
dibella989
Sep 1, 2015 04:12 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Fronzizzle
Aug 9, 2015 01:15 PM
