1989 Firebird: Trunk not opening, temp. gauge not working.
Old Nov 16, 2008 | 09:07 AM
Metallicelmo's Avatar
Hi guys,
All of a sudden my trunk won't open anymore.. If I press the dashboard-button nothing happens.. I think this must be a fuse problem.. The other thing is that my temp. gauge doesn't work either.. Might these problems be related? Could anyone tell me what fuse it should be and where to find it?
Old Nov 17, 2008 | 11:44 AM
HoodsBadBowTie's Avatar
Car: '83 T/A, '83 Firebird
Engine: Carb 350SB. Carb 305SB
Transmission: 700R4. 700R4
Re: 1989 Firebird: Trunk not opening, temp. gauge not working.
I got the same problem almost in my '83 Firebird the trunk won't open when I press the switch my temp gauge works fine though. I already checked fuses and they are all good. Did your temp gauge used to work and crapped out or never worked?
Old Nov 26, 2008 | 04:28 AM
But did you fix the problem? Or could the trunkmechanism have died on me?
Do you know where to find the fusebox? Is it located under the dash above the pedals?
AmorgetRS
Convertibles
Aug 31, 2015 11:55 AM
Roblyons
Interior Parts Wanted
Aug 30, 2015 12:07 PM
Jote4805
Aug 25, 2015 06:11 PM
justin57
Aug 20, 2015 07:05 PM
kyleb24
Aug 15, 2015 08:24 AM
