Mass air flow to MAP conversion.....
Old Nov 19, 2008 | 01:10 AM
Beggins's Avatar
Car: 1987 Trans Am GTA
Engine: 355 TPI
Transmission: 700R-4
Axle/Gears: 10 bolt limited slip with 3.42
What all is required to turn a MAF car to a MAP car?? Want to do this so I can have my supercharger and retain the TPI set up. Any info would be great guys ..........
Old Nov 19, 2008 | 02:23 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: Mass air flow to MAP conversion.....
Please read the tech article on this website that details the parts needed for the swap.
Since you're in the SoCal area, you can have Dyno Don do the swap for you, and I can do the custom chip tuning, if you want.
Old Dec 27, 2008 | 06:02 PM
cliff86's Avatar
Car: 1986 FIREBIRD
Engine: '89 5.O TPI
Transmission: 700 R4
Axle/Gears: 2.73:1 Posi
I made the swap using the conversion harness and ecm from TPI PARTS. It was about as simple as it gets and the whole thing cost under $500 about 2 years ago
chazman
Aug 28, 2018 03:25 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
chazman
Aug 22, 2015 02:01 PM
