GTA Subwoofer gain switch pinout
Old Nov 24, 2008 | 05:05 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
My car no longer has the stock subwoofers or amp, and I'm hoping to find a way to use the stock switch to control my aftermarket amp. Anyways, after a little experimenting with a spare switch tonight, I've figured out the switch pinout. I figured I would post it in case anyone else is looking to do something similar with this switch.
Note: I don't have a way to find backlight polarity by just looking at the switch - the bulb lights with polarity either way. This shouldn't matter anyways though, since you'll probably want to keep the backlight working - so just leave those wires on the harness unmodified.
Old Dec 15, 2008 | 01:01 PM
84redta's Avatar
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
Re: GTA Subwoofer gain switch pinout
Thank you Ward!!!! You've been a life saver, i'm getting carpul tunnel trying to search for something. Thank you very much!
Jon
Old Jan 29, 2014 | 10:18 PM
Firechicken86's Avatar
Car: 1989 Trans am GTA
Transmission: t56 6 speed
Axle/Gears: 3.45
Did you have any luck with getting this to work?
89GTAOz
May 16, 2020 09:31 AM
The_Phoenix
Feb 4, 2016 07:10 AM
Pilotrick50
Sep 2, 2015 12:48 PM
fasteddi
Sep 2, 2015 10:29 AM
Chuck84TA
Aug 27, 2015 11:14 AM
