Horn Question
Old Nov 24, 2008 | 08:59 AM
5 'O THIS's Avatar
Car: 1985 Z-28
Engine: 355 cid
Horn Question
I have checked the fuse, relay, horn button connection, etc., and I can not figure out why my horn is not working. It seems pretty straightforward, but I can't seem to figure it out. Any ideas?
Old Nov 24, 2008 | 09:22 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: Horn Question
Clean the terminals on the Horn(s) as well as the metal pins in the plug..... Then connect a voltmeter to ground and the horn wire and try the horn. If there is voltage than the horn should work.
If it doesn't work once you plug the horn back in - remove and re-install the bolt holding it to the frame. This bolt provides a ground for he horn.... if it still doesn't work - replace the horn(s) !
Old Nov 24, 2008 | 09:27 AM
5 'O THIS's Avatar
Car: 1985 Z-28
Engine: 355 cid
Re: Horn Question
Sounds like good info. What do you recommend cleaning the connections with...a scuff pad?
Old Nov 25, 2008 | 12:35 PM
5 'O THIS's Avatar
Car: 1985 Z-28
Engine: 355 cid
Re: Horn Question
Nope, nothing. I'm not getting any voltage from the green wire though...so I guess my search will go a little deeper.
Also, my windshield wipers are in the same boat...nothing...no power to the motor...the fuse on both of these are good, and the horn relay is new...is there something else that gthese run through?
Old Nov 26, 2008 | 02:13 AM
allenfre's Avatar
Re: Horn Question
Hmmm... Try running a jumper wire to the power connector on the horn, going to the positive battery terminal.
Old Nov 26, 2008 | 10:41 AM
LAFireboyd's Avatar
Axle/Gears: 9-bolt/3.45
Re: Horn Question
Nothing technical to add... just that I had a similar horn problem once. Turned out the green wire was broken.
Old Nov 26, 2008 | 11:34 AM
ACCLR8N's Avatar
Car: 87 Evoluzione, 84 TransAm, 05 GTO
Engine: LT1, L98, LS2
Transmission: (2) T56 & (1) 700R4
Axle/Gears: Moser 12-bolt w/3.73 & Stock
Re: Horn Question
Your horn button supplies the ground to the horn relay. There is no positive voltage to measure.
Bubbajones_ya
Aug 31, 2015 12:02 PM
tc7761
Aug 30, 2015 09:45 AM
Stauf
Aug 24, 2015 08:31 PM
redmaroz
Aug 16, 2015 11:40 PM
Keiffer76
Car Audio
Aug 9, 2015 11:37 PM
