4th Gen power seats wiring
Old Nov 25, 2008 | 09:19 AM
Frozer!!!'s Avatar
Car: '90 RS
Engine: Vortec 350
Axle/Gears: 3.23 non posi
Ive been looking to swap in a set of 4th gen leather seats and noticed that like 99% of them are power. The issue is I have manual seats now so I dont think I have a stock power harness. I have no Idea what the wiring ahrness looks like for power seats. Is it the same in a thirdgen as it is in a 4th gen. Is it simple enoguh where its just a 12 v source and ground or is there more to it? Any input or pics of the harness would help. Thanks
Old Nov 25, 2008 | 02:22 PM
pearl_iroc's Avatar
Car: 1988 Iroc-Z 28 Camaro
Engine: LSX
Transmission: MN12
Re: 4th Gen power seats wiring
i got mine out of a 95 or 96 t/a and basically on the drivers side theres a power and ground, then theres a few other colored wires u connect the passengers side seats wire harnnes to the drives seat wiring harness according to color. do a search theres tons of info
Old Nov 28, 2008 | 02:51 PM
tony_cogliandro's Avatar
Car: 1990
Axle/Gears: stock
im with you on this one. i have a nice set of leather seats i got out of a t/a - 98 and they clip into a harness under the seat. i was given a pigrail of the other wires from the seat and i will be damned if i can figure out where they go. there is no plug in there!
everyone says its so easy but its not. six wires that do not match the color of the ones in a 90 camaro, and that is for both seats.
also there is the lumbar control and no one can tell me where all the hoses go.
im taking pictures of the entire thing and will post them after it is all done.
but no, its not bolt and plug, and plan on spending a lot of time on it.
and that X under the front seat carpet where the plug is supposed to be, well it ain't there either.
so don't let anyone blow smoke up your butt about this.
im getting a complete wiring chart of the 1990 camaro and one of the 98 t/a so i know what is really what.
and yes i do have a special fuse already there for it in the fuse box, but does me no good at all.
and get someone to cut the bar off when you put in the new back seats too, it sticks out from the center, and will cut into your new leather seats. you will need to have them cut it from the center and then grind that piece down. dont just cut the bars off and leave the bump, it looks bad and people will scratch themselves on it, if anyone ever does sit in the back seat.
jaridjohn
Jul 8, 2024 03:49 PM
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
AkDrifted
Aug 17, 2015 07:45 PM
