Installing A Power Antenna Switch For Dummies
Old Dec 11, 2008 | 02:10 AM
Justin1989's Avatar
Car: 1989 GTA
Engine: 5.7L TPI 350
Transmission: Automatic
Hey there. This is like my third day here on the forums and I've gotten a ton of friendly responses so I figured I'd give somethin' back to you guys. This is a pretty simple guide, but if you don't want to gather the info that I had to and happen to stumble upon this, DO IT! It took me like 30 minutes, and I was taking pictures of the stuff for you while I was doing it.
Anyways, here's what we're doing here.
I got tired of my power antenna going up and down every time I got in the car, and I figured it was probably bad for the electric motor as well. So I went to Radioshack and bought a switch (more below, but keep reading) and spliced the power antenna wire and cut a hole under my dash near the steering column (very clean, very subtle) and ran two wires through it. I then
installed the switch and popped it into the hole. I reassembled the radio and bam! Sweet-*** button in case you need to actually listen to radio or your Ipod is dead.
So, to start this totally awesome task, you're going to need these materials:
Drill, Cone bit, electrical tape, some wire, a razor blade, a two-pronged switch from Radioshack, two wire nuts, and common sense as well as patience. You'll also want a flashlight, day or night time.
The switch will cost around $3.50 w/ California tax included.
Picture of items:
Closeup of Switch:
Remove your cover from your accessory tower:
Remove your stereo deck:
Find your pink wires, follow pic instructions:
Stop fondling your wires and cut a hole:
Run your wires to your location from your accessory tower:
Pull your wires out of your hole:
Connect spliced wires using wirenuts:
Old Dec 11, 2008 | 02:11 AM
Justin1989's Avatar
Car: 1989 GTA
Re: Installing A Power Antenna Switch For Dummies
Connect your switch:
Test your craft:
Put your radio in completely:
Pop your button in the hole:
Admire your sneaky crafty achievement:
And that's my guide on how to install a switch for your power antenna. Leave me any questions you have or comments!
Old Dec 11, 2008 | 08:24 PM
Justin1989's Avatar
Car: 1989 GTA
Bump!
Old Dec 13, 2008 | 08:47 AM
DyingYoung138's Avatar
Car: '86 Trans Am
Engine: 305 H.O.
Very nice guide. I would be doing this myself if I had a power antenna.
Old Dec 14, 2008 | 01:12 AM
webeeZ28's Avatar
Car: 1992 Z28 L98 G92
Engine: 5.7 350 B2L
Transmission: 700 R4
I enjoy your sense of humor. Although I too, don't have a power antenna , I really appreciate the way you illustrate your work. Keeping it simple for the rest of us... rock on
Old Dec 14, 2008 | 05:16 PM
Justin1989's Avatar
Car: 1989 GTA
Thanks. If anyone else does this or comes up with a different spot post it here, I'd like to see it!
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
89GTAOz
May 16, 2020 09:31 AM
Vintageracer
Jan 10, 2020 05:33 PM
Spd-Kilz
Interior Parts Wanted
Aug 15, 2015 12:12 PM
