fuses question
Car: 1990 RS tbi camaro
Engine: 5.0 tbi stock, hooker headers
fuses question
can a blown fuse for the interior lights blow the bulb as well, because i replaced the fuse and it doesnt work. also can the fuse box itself be a suspect because the area around where the fuse is put is burnt a little bit.
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
BRIGHT IDEA
You wrote you replaced the fuse.
You didn’t say you replaced the bulb but we’ll assume the bulb is OK for this discussion.
You also didn’t say if your new fuse blew.
If it did check for a short in the line.
Might be a pinched wire having an insulation rub-thru.
Happy Racing!
If People Drove Any Slower They’d Be Going Backwards
Ghettobird52
Jul 5, 2024 11:18 PM
