How is the battery supposed to be wired up (pic)
Old Dec 20, 2008 | 12:55 PM
5_Speed's Avatar
Car: 92 RS
Transmission: 7R4
Ok.. I thought it was obvious the red is pos+ the black is neg- but when I hooked the battery up, the thin wire coming from the neg- cable to the back of the alternator went up in smoke.
The red ended cable which he said was pos+ connects only to the alternator bracket
The black connected to the back of the alt (skinny black wire) and then a little further down, connects to an orange fused wire into the main harness, as well as going back to the starter I guess.. so
Is my red actually negative, and my black is positive? What is going on here.
Old Dec 20, 2008 | 01:23 PM
tom86iroc's Avatar
Car: 1986 iroc
Engine: alum. head 350 supercharged
Transmission: 6speed
Axle/Gears: ford 9in 3.90 35 spline moser axles
Re: How is the battery supposed to be wired up (pic)
yup they're backwards your red is ground u can see in the pic it bolts to alt bracket and the bl was probably installed after by someone they didnt get the right color u ALWAYS double check wires if YOU haven't installed them had the same problem on a customers car
Old Dec 20, 2008 | 02:29 PM
5_Speed's Avatar
Car: 92 RS
Transmission: 7R4
thank you, I'm so ashamed of myself .. haha. I fixed them up, and put in another new battery, so it should be all good now car fired right up and nothing is catching fire.
Old Dec 20, 2008 | 03:16 PM
tom86iroc's Avatar
Car: 1986 iroc
that's good got lucky sometimes i've seen alot of wiring get messed up by crossin the wires so you got lucky good luck
eightsixseven
Dec 16, 2024 01:50 PM
Rakim_RS25TH
Car Audio
Aug 20, 2015 06:22 PM
Rakim_RS25TH
Aug 18, 2015 09:32 PM
sonu1975
Aug 11, 2015 08:38 AM
