where can i locate an ignition wire?
Old Dec 22, 2008 | 08:11 PM
Bobby_80s's Avatar
Car: 1987 Camaro, 1986 Trans AM
Engine: V6 2.8 multi-port and V8 5.0 FI
Transmission: 5-Speed and Automatic
Axle/Gears: no idea
hey guys im installing a car pc computer and the power supply has 3 terminals
ground
12v
and ignition
where under the dash can i find the ignition wire "exactly" and waht color wire should it be
its under the steering columb isnt good enough alittle more descriptive would be a big help
thanks guys
Old Dec 25, 2008 | 07:12 PM
Fullsizewagon's Avatar
Engine: '85 Monte SS L69 305
Transmission: TH 200-4R
Re: where can i locate an ignition wire?
How much power does it draw?
The pink/black wires that you'll find all over the place are fused with 20A I think. Or how about taking it straight from a terminal in the fuse box? There are both constant 12V and switched 12V outlets there.
Wiring diagrams can be found at autozone.
Old Dec 26, 2008 | 12:59 AM
Bobby_80s's Avatar
Axle/Gears: no idea
ok thanks i'll take a look into it
im not sure how much power just knwo its made to be installed in cars and requires 12v ground and ignition signal cuz its a smart power supply that is supposed to slowly turn on/off teh computer so i'm guessing it needs the ignition wire to get that reserve power so teh computer isnt instantly unplugged so to speak
Ghettobird52
Jul 5, 2024 11:18 PM
Hellbillydeluxe
Sep 22, 2015 09:58 PM
Rakim_RS25TH
Car Audio
Aug 20, 2015 06:22 PM
Rakim_RS25TH
Aug 18, 2015 09:32 PM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
