ignition wire = 12v constant always on orange wire?
Old Dec 23, 2008 | 12:40 PM
Bobby_80s's Avatar
Car: 1987 Camaro, 1986 Trans AM
Engine: V6 2.8 multi-port and V8 5.0 FI
Transmission: 5-Speed and Automatic
Axle/Gears: no idea
i need access to an ignition wire is it the same thing as a 12v orange wire thats constantly on?
Old Dec 23, 2008 | 12:51 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Re: ignition wire = 12v constant always on orange wire?
What are you trying to hook up?
Old Dec 23, 2008 | 12:53 PM
Bobby_80s's Avatar
Axle/Gears: no idea
i asked in a thread yesterday where i can get access to an ignition wire and no one responded i did once before and no one was specific or said just do a search
im installing a car computer and i need to find 12v ground and ignition wire
12v and grnd i can find i need access to an ignition wire under the steering columb or wherever
Old Dec 23, 2008 | 12:54 PM
Jeff91RS's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: World Class T-5
Axle/Gears: 3.27 9-Bolt LSD
ignition is power that is on while the key is on and during the cranking cycle. the best location is at the pink wire coming down from the steering column. very different from 12v constant.
Old Dec 23, 2008 | 01:03 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
.............i need access to an ignition wire under the steering columb or wherever
If you need a switched 12v source, there should be one on the fuse block. It'll be a single male blade marked, "IGN".
Once you find it, verify it's a switched source using your volt meter or test light.
Old Dec 23, 2008 | 01:04 PM
Bobby_80s's Avatar
Axle/Gears: no idea
ok thanks, is that wire the same that gets the car started from teh key cuz i need an ignition wire from that area for thios securty box im installing and it stops ugn teh car before typing in a code
Old Dec 23, 2008 | 01:13 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
The terminal at the fuse block isn't a wire. It's just a terminal that is 12v with the key on, 0v with the key off. That's all it does.
This security thing disables the ignition circuit or the starter circuit?
Where does the installation instructions say to hook it up?
Old Dec 23, 2008 | 01:19 PM
Bobby_80s's Avatar
Axle/Gears: no idea
il get back to u on that when i get home im almost certain its ignition but ill double check
89GTAOz
May 16, 2020 09:31 AM
Glowsock
Jan 9, 2017 04:06 PM
Rakim_RS25TH
Car Audio
Aug 20, 2015 06:22 PM
Rakim_RS25TH
Aug 18, 2015 09:32 PM
apie2546
Aug 8, 2015 07:12 AM
