Fog Lights
Car: 1987 Iroc-Z28
Fog Lights
I have a 1987 Iroc-Z 5.0 TPI with fog lights in the grille. Both of them just stopped working. How would I go about replacing them or checking what's the problem.
Car: 87 GTA
Re: Fog Lights
Check the other stuff first. Changing the housing won't affect the lights operation either way.
If both went out together, my bet is a fuse or the switch itself.
Car: 87 GTA
Re: Fog Lights
Depending on where you show voltage exists, it'll tell you where to start looking for the power loss.
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Fog Lights
Shot in the dark: Your fogs won't work with the high beam on.
JamesC
JamesC
Car: 87 GTA
Car: 87 GTA
Re: Fog Lights
Test for power at they bulb. If you don't have power there, pull the switch. See if it has power going in & going out.
Real simple...Get yourself a test light are start testing........
Re: Fog Lights
According to Tim Burgess, "on Camaros the relay was moved from the driver's side fender to near the fuse panel under the dash sometime between '87 & '92."
JamesC
JamesC
Car: 1989 Camaro RS
Engine: V6 - LS Swap Incoming
Transmission: 700R4 - T56 Mag F Incoming
Re: Fog Lights
Mine are wired straight in the power for the hi beams. I have no switch they come on when I turn regular lights on. How it should be from the factory in my opinion but hey whatca gonna do?
Get a voltmeter and test at the fog light assemble for power. If none is present then work your way back to the relay (its under the dash in 89 and up) and see if it's bad wires, bad relay, or bad connection on switch.
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
IN L.A. DO I NEED SMOG LIGHTS ?
After you're finished, note that for maximum effectiveness in fog you want the choice to have the fog lights only on.
Having excessive lights on during normal conditions just looks dorky and makes people think the driver must have poor eyesight.
Happy Racing!
If People Drove Any Slower They’d Be Going Backwards
Car: 1987 Iroc-Z28
Re: IN L.A. DO I NEED SMOG LIGHTS ?
I'll check the lights and switch for power, then check the relay and let you guys know what happens.
Thanks a lot.
Might not get around to it til later since I work till late.
Thanks a lot.
Car: 1992 firebird
Engine: V6
Axle/Gears: 10 open 3.42
Re: Fog Lights
ok i had the same problem the bulb on the driver side is a link for the second blub so if the driver side one goes out the the passager side is out to did u replace the blubs?
Car: 1987 Iroc-Z28
Re: Fog Lights
No I need to check if it's the bulbs. How do I remove them? I don't see any screws, only the ones to adjust the fog lights
florida_gators
Exterior Parts Wanted
Sep 7, 2015 07:19 PM
