ECU Upgrade question??
Car: 91 Camaro RS
Engine: 305 bored 40 over, Built For Auto X
Transmission: 700r4, swapping to a T-5
OK I'm swapping my trans(700r4-t5) When ordering an ECU upgrade through JET it asks if its auto or stick. My Question is, since my ECU was made for an auto, would I have to get the JET for a manual or an auto. Maybe a dumb question. I'm just wondering cause I would think that computer wouldn't see the signal from an auto trans.
Engine: '85 Monte SS L69 305
Transmission: TH 200-4R
Re: ECU Upgrade question??
Don't quote me on this, I'm not an authority, but:
In principle you'll want the manual programming, and then you'll want a manual wiring harness for it since there are most likely (small) differences in signals & pinouts.
There may be workarounds so you won't need a whole new harness but others will have fill in on that.
Looking at both models wiring diagrams would reveal what (if anything) needs to be done.
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Since you're putting in a manual transmission, you want a manual chip in the ECM.
Actually, there is no need to buy a whole new ECM. You can just buy a new manual chip and replace the automatic chip. It simply pulls out of the ECM.
Hope this helps.
Lou
Hope this helps.
Lou
eightsixseven
Dec 16, 2024 01:50 PM
