91 camaro rear break light
Old Jan 3, 2009 | 01:19 PM
xsupermann69x's Avatar
Car: 1991 Chevy Camaro RS
Engine: V6 3.1L
Transmission: automatic
yeah so um my upper rear break light doesnt work. i tried a bulb and nothing. the fitting is sort of loose. idk much about electronics. any ideas?
Old Jan 3, 2009 | 02:34 PM
kcb37's Avatar
Re: 91 camaro rear break light
I would say to check the fuses, doubt it will do any good though, should be all three brake lights on one fuse.
You will want a test light or multimeter. With that see if you have power.
If you do, then the bulb has a bad connection, or it's not grounding.
If you don't have power you will have to follow the wires back until you find power. Then figure out why. Could be an plug loose, or a broken wire.
This is also where a wiring diagram is handy to see where the wires go.
jaridjohn
Jul 8, 2024 03:49 PM
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
Omega
Aug 10, 2015 12:46 PM
NBrehm
Exterior Parts for Sale
Aug 5, 2015 08:19 PM
