hid kit
Old Jan 4, 2009 | 01:51 AM
tireburningZ's Avatar
Car: 91 Z28
Engine: 5.7 tpi
Transmission: t-5
Axle/Gears: limited slip 3.42
hid kit
can anybody recommend me a good hid kit? the only one i know of is the painless harness for the kit. im in severe need of changing my headlights they are horrible for both safety and looks.
Old Jan 4, 2009 | 07:49 AM
Stephen's Avatar
Car: 87 GTA
Re: hid kit
I got new Sylvania Silverstar sealed beams because I live out of town...No road lights out here & deer crossing the road is BAD......
The visibility is amazing & WAY cheaper than HID lights. My 2 Pontiac Hi/Low lights were $20 each.
Then to top that off, I swapped out my stock H3 fog light bulbs for Sylvania Silverstar H3 bulbs....$40 for the pair.
I really don't see the point of spending the $$$ needed to go HID + the mounting & rewiring needed, when the Silverstars are a DIRECT plug-in.
Old Jan 4, 2009 | 08:10 AM
FYRCHKN's Avatar
Car: 1988 SC Convertible
Engine: LT-1
Axle/Gears: 3.23 posi w/PBR's
Re: hid kit
+1, I have the same exact setup.
Old Jan 4, 2009 | 01:10 PM
Car: 91 Z28
Engine: 5.7 tpi
Transmission: t-5
Re: hid kit
bare with me here please because i have no idea where to begin with wiring me and electrical stuff just dont seem to get along. i had read that if you do an h4 swap you needed to upgrade the factory wiring by making your own relay harness. but you said yours were just drop in and plug.
Old Jan 4, 2009 | 04:15 PM
Stephen's Avatar
Car: 87 GTA
Re: hid kit
Ours aren't H4s....Ours were DIRECT REPLACEMENT sealed beam headlights. And our (at least mine are, not sure about the 91/92 fog lights) fog lights are H3 bulbs, not a sealed beam type.
If you aren't comfortable with rewiring, get the Silverstars. They simply replace whats there & require NO modification at all.
I tried non-HID H4 bulbs in different headlight housings.....Whether it was a bad/low output of light H4 bulb, or a bad housing with low reflection/light output...I dunno. I just know they SUCKED. I'm sure if they had been true HID H4s, they woulda been better. But the price different between the direct drop-in Silverstars vs the cost of true HIDs? HIDs aren't worth it, IMHO.
Old Jan 4, 2009 | 06:04 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Re: hid kit
HID kits are'nt really that expensive anymore, unless you condsider spending up to $150 expensive.Some HID kits are under $100 & are true P&P.No cutting/splicing,drilling,etc.The greatest advantage to HID isnt just the better light ouput, but the lower wattage required to run them, 35w Vs 55-65 for halogens & silverstars are still halogen lights & HIDs will illuminate with the intensity of an 85w bulb @ only 35w requirement.There is savings to taxing your electrical system with lower current draw.Like more power to your ingition, stereo, cooling fan & an easier life for your alternator.HIDs will also far oulast any halogen light.So there is some saving there as well.Plus you can transfer the kit to another car.Provided the next vehicle uses the same type of lamp.Dont get me wrong though i like silverstars & had them on my camaro, but the Xenarcs on now & the HID kits i installed on both my bikes are far better!
Old Feb 2, 2009 | 06:58 PM
KITT1983's Avatar
Car: 1983 Pontiac Trans Am Daytona 500
Engine: Crossfire 305ci V8
Transmission: Jasper 700R4 4 speed Automatic
Axle/Gears: 3.23 limited slip/posi
Re: hid kit
I got Hella E-Codes 200mm (4x6) (H6054-H4 conversion housing)
here is a link
http://www.rallylights.com/detail.aspx?ID=354
Old May 23, 2009 | 01:21 PM
allgood's Avatar
Car: 92 WS6 Trans am convertible
Engine: ls 6.2
Transmission: 4l80
Axle/Gears: 2.73's
Re: hid kit
here is a link
what hid kit did you with these lens
Old May 23, 2009 | 01:49 PM
allgood's Avatar
Engine: ls 6.2
Transmission: 4l80
Axle/Gears: 2.73's
Re: hid kit
Originally Posted by 84 1LE
HID kits are'nt really that expensive anymore, unless you condsider spending up to $150 expensive.Some HID lits are under 100 bills & are true P&P.No cutting/splicing,drilling,etc.The greatest advantage to HID isnt just the better light ouput, but the lower wattage required to run them, 35w Vs 55-65 for halogens & silverstars are still halogen lights & HIDs will illuminate with the intensity of an 85w bulb @ only 35w requirement.There is savings to taxing your electrical system with lower current draw.Like more power to your ingition, stereo, cooling fan & an easier life for your alternator.HIDs will also far oulast any halogen light.So there is some saving there as well.Plus you can transfer the kit to another car.Provided the next vehicle uses the same type of lamp.Dont get me wrong though i like silverstars & had them on my camaro, but the Xenarcs on now & the HID kits i installed on both my bikes are far better!
you say you got xenarcs, do they make a kit for a 92 trans am
Old May 23, 2009 | 02:30 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Re: hid kit
Im not positive, but i believe sylvania never made a 6054 style xenarc kit.Doubt it matters though.They stopped producing the xenarc system some years back.
Old May 24, 2009 | 07:13 AM
KITT1983's Avatar
Re: hid kit
A H4 BiXenon Kit
There is a mustang site I would recommend:
http://www.lastcallracing.com/
there is also a Rhode Island guy I would recommend
TOC Whip Appeal" 410 Broad st. Central Falls 02863
Store hours:
Mon-Sat
10am-8pm
Sunday- Closed
(401)369-5562
(401)651-9447
and try this one too
www.mobilehid.com
Use this H4666 kit for your 1992 Trans Am
Hella H6545 165mm ECE Hi-Lo H4 Conversion Headlamp Kit
H6545 165mm ECE H4 Hi-Lo Conversion Headlamp Kit.
Replaces 4652, H4656, H4666 H4668, H6545, H6545BL, and HP6545 Sealed Beams. Includes two lamps, two wiring adapters and two H4 bulbs.
http://www.rallylights.com/detail.aspx?ID=64
here is a tip for when buying hids
Yes that Hella housing is correct for the 1982-1984 Trans am. I posted that same one in my post above.
I recommend you stay away from Chinese made H.I.D. Kits and I know from experience (I got screwed twice by bad Chinese made bulbs). Remember this you buy The EBay ones at to your own risk!! I recommend you go with American made or German made H.I.D. Kits they are a little pricey but well worth it.
Ask the seller:
Where are you based out of?
Do you have any complaints?
Who manufactures this HID kit?
Are these true BI-Xenon HIDs?
What is your warranty policy?
https://www.thirdgen.org/forums/elec...ersions-2.html
Old Jul 7, 2009 | 04:25 PM
calamitascamaro's Avatar
Car: 1992 RS 6spd
Engine: Carbed 357c.i.
Transmission: Built T56
Axle/Gears: Soon to be Strange S60
Re: hid kit
here is a link
I got E-codes for my Camaro on the same site, called first and the owner answered the phone, very informative, incredibly courteous, shipped fast. Chinese HID's suck, went through two $60 sets before I bought a quality H4 Bi-xenon german kit. Light output is incredible, and on Camaro's, all you have to do to connect the ballast wiring to the original is repin your original harness to be set-up for H-4 lighting. There is a write-up on here on how to do that as well.
Old Jul 7, 2009 | 04:35 PM
KITT1983's Avatar
Re: hid kit
do you have a link to these German HIDs
Ronald Reagan once said Trust, but verify
Old Jul 7, 2009 | 05:27 PM
Car: 1992 RS 6spd
Re: hid kit
Philipsxenon.com
Old Jul 7, 2009 | 05:39 PM
all4u's Avatar
Car: Firechicken
Engine: 350 + 30 over, 400 crank
Transmission: autotragic, stalled
Axle/Gears: not a one tire fire, thank god!
Re: hid kit
I've been happy with my trublu ballasts for the past two years. They are very bright and last a long time. I only spent $150 on them and I did the install myself. I wish those would go back on sale, I buy more of them if I had the chance so I could put them on my other bird.
Old Jul 7, 2009 | 05:53 PM
HarmonyCamaro's Avatar
Car: 83 Z28 Camaro
Transmission: 5 Speed manual
Re: hid kit
o have a thread and the website i bought my hids i should put the new pictures up but to lazy to... here is my link
and the hid set i used has the wireing kit needed.. all you need to do is change the pins around. i can give you what you need to change pin around but idk if it the same for firebirds/trans am has the fuse in line aswell just a plug and play.
https://www.thirdgen.org/forums/elec...tallation.html
i posted the new pics
Old Jul 7, 2009 | 06:06 PM
KITT1983's Avatar
Re: hid kit
link please
Old Jul 9, 2009 | 09:17 AM
allgood's Avatar
Engine: ls 6.2
Transmission: 4l80
Axle/Gears: 2.73's
Re: hid kit
do they give that blue look
Old Jul 9, 2009 | 09:29 AM
allgood's Avatar
Engine: ls 6.2
Transmission: 4l80
Axle/Gears: 2.73's
Re: hid kit
what brand you used and from where
Old Jul 9, 2009 | 09:34 AM
Stephen's Avatar
Car: 87 GTA
Re: hid kit
Thankfully, no. I care more about what my eyes see out of the car, than what others eyes see looking at my car.
They are a bit more white than the standard yellow-ish light though.
Old Jul 9, 2009 | 11:36 PM
all4u's Avatar
Car: Firechicken
Re: hid kit
I didn't purchase them online. I got them from a local electronics shop. He was selling them cheap because he had so many sets that weren't moving. I could get more sets for members on the board but shipping might be a bugger.
Old Jul 10, 2009 | 06:05 AM
KITT1983's Avatar
Re: hid kit
photos we need photos and how much for the HID kit + shipping?
Old Jul 10, 2009 | 02:47 PM
all4u's Avatar
Car: Firechicken
Re: hid kit
I'll see if I can get some photos of them. I would like to be able to send these local if possible because I know that with shipping, you could find HIDs elsewhere. I'll see what I can throw together cause my digital camera is a POS.
Old Sep 2, 2009 | 12:24 PM
bcfipp's Avatar
Re: hid kit
kitt1983, did u buy the housing empty, then bought the hid kit.
Old Sep 2, 2009 | 12:30 PM
KITT1983's Avatar
Re: hid kit
yes and it was cheaper that way
Old Sep 2, 2009 | 12:31 PM
Twin_Turbo's Avatar
Re: hid kit
That site philipsxenon looks like a fake. Philips is a Dutch electronics brand and they do make HID systems (Philips/Osram originated the HID stuff in Mercs and Bimmers back in...oh 94 or so?) They only make OEM HID/Xenon products.
Anyway, the actual Philips site is this:
http://www.lighting.philips.com/in_e...ghting&lang=en
Old Sep 2, 2009 | 12:44 PM
bcfipp's Avatar
Re: hid kit
Was the kit a plug and play
Old Sep 2, 2009 | 12:51 PM
KITT1983's Avatar
Re: hid kit
http://www.lastcallracing.com/1979-1...rsion-kit.html
Old Nov 9, 2009 | 10:18 PM
90 L98 TransAm's Avatar
Car: 90 L98 TA, 03 WRX
Engine: Vortech Supercharged 5.7 L
Re: hid kit
Sylvania did make a 6054 Xenarc (HID/halogen) kit and they are still available from a few vendors:
http://www.suvlights.com/product_inf...roducts_id=270
I've read several reviews on them in different automotive forums. Some said they are trash and others said they provide much better light than stock. Based on my personal experience with a set of the Sylvania Xenarc X1010 driving/fog lights I just snagged a new set of the Sylvania's Xenarc X6054s (for 70% less than the vendors' prices).
Old Nov 9, 2009 | 10:29 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Re: hid kit
Damn, look what else they have!!
http://www.suvlights.com/product_inf...roducts_id=268
Old Nov 10, 2009 | 05:21 AM
KITT1983's Avatar
Re: hid kit
do these have hi and low beam? the listing does not say
Old Nov 10, 2009 | 10:43 AM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Re: hid kit
The HID- Xenon Sealed Beam Headlight Kits Include:
2 Osram Sylvania D1R Powered HID Low Beam Lamp Assemblies (X6024 & X6054 have an integrated high beam in the same headlight)
2 Osram Sylvania H1 (55W) Powered High Beam Lamp Assemblies (except X6024 & X6054 which have an integrated H3 - 55W)
Two Osram Sylvania D1 Electronic Ballasts
Two Wiring Harnesses With Relays (our exclusive headlight mating sockets eliminate need to cut existing factory headlight sockets)
Two Ballast Mounting Brackets
All Necessary Mounting Hardware
Old Nov 10, 2009 | 11:11 AM
Stephen's Avatar
Car: 87 GTA
Re: hid kit
How are they HIDs AND sealed beams?
Old Nov 10, 2009 | 12:05 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Re: hid kit
Not exactly sure how they define sealed beam, but the housings do use an o-ring for the HID lamp.Along with a retaining clamps w/4 screws to hold the lamps secure.
Its not a permanent seal like sealed beam units, but it is sealed from the elements.
Old Nov 12, 2009 | 03:49 PM
godjackass's Avatar
Car: 1987 iroc
Engine: blown up for now
Axle/Gears: 10 bolt/stock
Re: hid kit
i got lucky a couple months ago and got some of the xenarc x4656 off ebay for 150 shipped. he said he had a few sets, and i tried to buy all of them, but i was too late, and only got one set. havent installed them, gotta finish the car first, but i didnt want to pay $588 for them from suvlighting.com im curious 841le, how do you like yours?
Old Nov 12, 2009 | 04:40 PM
Re: hid kit
You scored too!
Do they say where they are made? Do they look like a quality product? Have you tested them to make sure they work? Do a thread when you install them.
Old Nov 12, 2009 | 07:26 PM
godjackass's Avatar
Car: 1987 iroc
Re: hid kit
its probably going to be a few years before i get mine in. im waiting for 841le to chime in and let us know how he likes his.........
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
1Aauto
Sponsored Vendors
Jan 15, 2016 06:25 AM
1Aauto
Sponsored Vendors
Sep 22, 2015 03:39 PM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
