Determining Problem with Opening Hatch?
Old Jan 5, 2009 | 01:11 AM
DyingYoung138's Avatar
Car: '86 Trans Am
Engine: 305 H.O.
I've got an '86 Trans Am and have problems with the hatch opening correctly. Pressing the button does basically nothing unless I have someone tug up on it at the same time of pressing the switch.
Got any ideas?
Old Jan 5, 2009 | 10:07 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
HATCH LATCH
Can you hear a CLICK when you use the hatch release switch?
Happy Racing!
If People Drove Any Slower They’d Be Going Backwards
Old Jan 5, 2009 | 10:20 AM
Car: '86 Trans Am
Engine: 305 H.O.
Re: HATCH LATCH
Only when someone is pulling on it while I press. Otherwise nothing happens at all. So I NEED two people to open my hatch. lol.
Old Jan 5, 2009 | 12:04 PM
NINÅ's Avatar
Transmission: 765R4
HATCH LATCH BATCH
Because your description seems to indicate you’re getting power in and out of the switch the problem might be mechanical.
Also you didn’t indicate the gas lifts were not completing the raising once your helper lifted the hatch.
Therefore check the spring which flips the latch open for breaks / jams.
Check the latch for bends and binding.
Happy Racing!
Old Jan 5, 2009 | 01:57 PM
Car: '86 Trans Am
Engine: 305 H.O.
Re: HATCH LATCH BATCH
No, the struts do not work. I have to hold the hatch up when it is open.
I'll check back there here in just a few moments. I'll get back with ya.
EDIT:
Alright, I went out there with the fiance and had her press the button while I tugged. Opened first try when two people are manning it. I pulled off the panel covering the pulldown motor and all that, but couldn't seem to locate any type of spring.
Old Jan 6, 2009 | 11:11 AM
NINÅ's Avatar
Transmission: 765R4
HATCH LATCH MATCH
The spring will not be apparent.
It’s off to the side of the latch.
Also if the spring is broken or is missing obviously it won’t be seen.
If you’re mechanically inclined remove the mechanism and check for / replace the spring.
If you’re not mechanically inclined replace the entire mechanism.
It’s a faster pit stop that way.
Happy Racing!
Street Lethal
Apr 30, 2019 12:14 PM
AmorgetRS
Convertibles
Aug 31, 2015 11:55 AM
neekolzun
Aug 24, 2015 04:59 PM
madsv1000
Aug 20, 2015 06:45 AM
