Distributer Not Seating Right? Feels tight.
Old Jan 5, 2009 | 10:11 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
I cant get my distributer on correctly. I can get it tight on, but it wont seat down to the gasket. There is like an 1/8 inch gap so the gasket is useless. Is this supposed to be like that? What is going on?
Old Jan 5, 2009 | 10:14 PM
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
Transmission: 700-R4
Re: Distributer Not Seating Right? Feels tight.
Are the ignition control module wires blocking it from seating ? Make sure the spinner on top of the shaft, under the dist, is fully seated.
Old Jan 5, 2009 | 10:19 PM
BOSS 357's Avatar
Car: 89RS,89TBI FB, 91Z28, 89TPI FORMULA
Engine: 357 SBC TPI
Transmission: World Class T-5 (for now)
Axle/Gears: Strange 12-bolt 3.73
You're sitting on the oil pump shaft. I think you need to have the rotor just before or after (1/8" maybe?) the point at which you want it to end up pointing. What needs to happen is you manipulate the shaft to seat on the dist and the cam gear will rotate the button into the correct position. You can use a long screwdriver or something like that to manuver the OP shaft into the correct position. After you've done it once, it will be so much easier the second time.
Old Jan 5, 2009 | 10:21 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
I felt it hit the grooves. It turned too, but it will not go down. I had the clamp on it and used the bolt to pull it down and it didn't budge. It is tight in there and I know it is in the grooves.
Old Jan 5, 2009 | 11:15 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
What do I need to do to get it seated? Should it just slide down all the way?
Old Jan 5, 2009 | 11:36 PM
Drinkmorebeer's Avatar
Car: 1989 Iroc Z T-Topin
Engine: 5.7L TPI
Axle/Gears: 9 bolt
rotate your oil pump with a screwdriver till it seats.
Old Jan 5, 2009 | 11:37 PM
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
Take the dist back off, make sure the spinning peice on top of the shaft is pushed all the way down, make sure no wires are in the way, and it should go down all the way. Me and drinkmorebeer took his off, put it back on without a problem. Sounds like ur snaggin a wire ! Can u snap a pic of the dist off ? and one how it is now?
Old Jan 5, 2009 | 11:38 PM
Engine: 5.7L TPI
Axle/Gears: 9 bolt
yeah but he was 180 off...so i dont think its gonna sit the same...
Old Jan 5, 2009 | 11:39 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Ill get some pictures in about 15 minutes.
Old Jan 5, 2009 | 11:41 PM
scribbles's Avatar
Car: 88 gta
Engine: 350 tpi
Have you tried moving the rotor with your hand back and forth to get it to catch. It sounds like it is sitting on the pil pump shaft. turn it an 1/8 and drop in and both ways. should catch. I think you are 1 tooth off.
Old Jan 5, 2009 | 11:42 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
If I was a tooth off would it cause it to not line up?
Engine: 5.7L TPI
Axle/Gears: 9 bolt
Maybe you should sell me you car for $500 i might be able to figure it out.
Old Jan 5, 2009 | 11:44 PM
scribbles's Avatar
Car: 88 gta
Engine: 350 tpi
Just re-time the motor. Stop messin around and just re-do it from the begining. turn it over till #1 is on the compression stroke, fiddle with the dizzy till it drops back in, and set timing. If I need to I will drive out to chico and do it for you. You are making the GTG.
Old Jan 5, 2009 | 11:46 PM
Engine: 5.7L TPI
Axle/Gears: 9 bolt
me n rough gotta do mine this weekend to see if im 180 off. Btw rough i wont get off work till 730 on friday. So ill either be late or have to do it on sat.
scribbles's Avatar
Car: 88 gta
Engine: 350 tpi
Yes, the oil pump has a little slot in it, if you are 1-2 teeth off it will not fit in the slot in the oil pump shaft. It will go most of the way down but not all the way.
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Come on down. I know that the cap is pointing the right way for sure. It just wont go down all the way. I have to have it fixed by tomorrow or I don't think I will be able to make it.
Old Jan 5, 2009 | 11:47 PM
Engine: 5.7L TPI
Axle/Gears: 9 bolt
tomorrow is tuesday....you have till sunday.
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Here, I'm going to go try it again for yall. I really want to go to the gtg.
The car hasn't really been driven in 4 months and I really don't want to break down on the way to sac. I will need to drive it for a few days to make sure it is running good.
I'll be right back.
Old Jan 5, 2009 | 11:50 PM
Engine: 5.7L TPI
Axle/Gears: 9 bolt
how you think i feel about driving 3x your distance...i just paid 70 bucks for wheel bearings.
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
You got it man ! ALways helps to take a break and give it another go! You said there was some gasket ? I have never used a gasket for the dizzy.
for the front ? 4 bearings ?
Old Jan 5, 2009 | 11:51 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Yep, there is a gasket. Yeah, my dad didn't use one last time he did it.
Engine: 5.7L TPI
Axle/Gears: 9 bolt
probably duck tape...rigged like my fan switch
Old Jan 5, 2009 | 11:53 PM
scribbles's Avatar
Car: 88 gta
Engine: 350 tpi
oh my god. you two need help. good night.
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Haha... Ill finger it out.
Old Jan 5, 2009 | 11:59 PM
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
try taking that gasket off
Old Jan 6, 2009 | 12:00 AM
Engine: 5.7L TPI
Axle/Gears: 9 bolt
No comment on that....Avoiding language ban.
Yeah all 4 bearings and seals...70.
Ill pack em tomorrow i guess if i feel like it.
Old Jan 6, 2009 | 12:03 AM
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
Id hold out till you get new rotors, that way you wont have to replace them again when you replace the rotors
Old Jan 6, 2009 | 12:05 AM
Engine: 5.7L TPI
Axle/Gears: 9 bolt
i dont need rotors though..imo..i guess i could wait till i redo my whole front end.
Old Jan 6, 2009 | 12:08 AM
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
Its your call Im not sure how hard it is to get the old bearings out. I know the cups are pressed in.
Old Jan 6, 2009 | 01:03 AM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Damn. I was out there for an hour. I got it on, But I am not sure if it is 180* off yet. I think I have it right though. Just need to put the cap and plugs back on, then hook up the wires to my distributer... Then we will see!
Old Jan 6, 2009 | 01:04 AM
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
You da man !
Old Jan 6, 2009 | 01:07 AM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Yeah well, we will see tomorrow how it is running. That will be the determining factor for sunday.
Old Jan 6, 2009 | 10:30 AM
Engine: 5.7L TPI
Axle/Gears: 9 bolt
stop being a drama queen and fix it
Old Jan 6, 2009 | 02:17 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Are you always on? You have over 100 posts in less than a month. Post *****
Old Jan 6, 2009 | 02:41 PM
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
Military life, your always on
db057
Apr 28, 2019 07:45 AM
NastyEngines
Group Purchases
Sep 8, 2015 10:14 AM
scottmoyer
Sep 7, 2015 07:06 PM
Out-Cast
Canadian Region
Sep 4, 2015 10:13 AM
