HEATER DOES NOT WORK.
Old Jan 6, 2009 | 07:21 PM
weswisehart's Avatar
Car: 91 RS T-top
Axle/Gears: 3:42 fourth gen disk brake
I dont really know where the wiring goes after it leaves behind the switches but behind or under the dash the wiring is fine. Any ideas? O also the a/c doesnt work but im not wooried about that but I know the switches are all together. No fan blowing.
Old Jan 7, 2009 | 09:00 AM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Re: HEATER DOES NOT WORK.
It could be as simple as a blown fuse (called HTR A/C). It should be 25A.
Another possibility is the wiring, it goes under the dash and through the firewall next to the heater box. Then it comes up and connects to the blower harness under the hood.
Also, check the connections at the blower, the relay and the resistor pack.
This diagram might help: http://www.austinthirdgen.org/mkport..._continued.gif
Lou
Old Jan 7, 2009 | 09:01 AM
firebirdland's Avatar
Car: 91 ,82 trans am 79 t/a
i'm not sure about the wiring, but can you hear the vacume moving the heater when u move it to the vents or defroster? there is a small rubber diaphram or gasket in the heater control, when it goes bad , u cant change the setting. if u have no blower at all, check for power at the blower motor under the hood. maybe blower is bad. i just had to replace mine the other day. the only way mine would work, was to tap the blower motor with a wrench. then it stopped blowing , and needed replacing. good luck
Old Jan 9, 2009 | 04:20 PM
Car: 91 RS T-top
thanks for the info.I have checked all the wiring and it looks fine. I noticed I get heat to the windshield but its not blowing. I will replace the blower. I priced it at autozone for 26.00. not bad.
Bubbajones_ya
Oct 25, 2015 08:01 PM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
