HEADLIGHT ONLY ONE HEAD LIGHT WORKS OTHER ONE IS VERY DIM
Old Jan 6, 2009 | 11:15 PM
ILUVMY89's Avatar
CAN SOME ONE TELL ME WATS UP WITH MY HEADLIGHTS I BOUGHT NEW BULBS ALSO MY RIGHT REAR TURN SIGNAL IS DIM AS WELL I PUT A NEW BULB IN THERE TOO THE CORRECT ONE AD ITS STILL DIM WHEN I HAVE THE BLINKER ON BUT WHEN I TURNED THE HAZARDS ON THEY WERE BLINKING FULL FORCE
Old Jan 7, 2009 | 11:37 AM
RockJay81's Avatar
Car: 84 Z28......99 TA
Engine: Lq9 6.0... Ls1
Transmission: 4L60E X's 2
Axle/Gears: 3.73 on both
Re: HEADLIGHT ONLY ONE HEAD LIGHT WORKS OTHER ONE IS VERY DIM
check the relay switch on the steering wheel column its white and when you flick the high beam lever it should click. i had that problem last month i got that replaced and its fine now plus check the female ends of the head light wiring harness they melt sometimes. lmk what you fine out
Jason
Old Jan 7, 2009 | 03:16 PM
rodrob1961's Avatar
Car: 2003 SILVERADO /86 IROC/85 S10
Is the dim headlight on the same side as the dim turn signal? It could be a weak ground. My 82 z28 has a ground at each headlight.
Old Jan 7, 2009 | 03:22 PM
RockJay81's Avatar
yeah check the ground if you take the inspection panel off of the fuse box you can see the white relay switch check that to see if everything is tight if not poke around with a test light and see where your ground is faulty
Old Jan 7, 2009 | 07:27 PM
ILUVMY89's Avatar
can i see a pic of what your talkin about what white swtch i put a new harness to the bulb and its still the same dim weres this inspection panel? and white switch
no opposite sides
Old Jan 9, 2009 | 11:46 PM
ILUVMY89's Avatar
im going crazy i have to find out wat the problem is im thinking about runnin a inline switch to the light thats dim that way it will work i cant believe no one has had this problem
Old Jan 21, 2009 | 04:04 PM
Blk91Firebird's Avatar
Car: 91 Firebird, 89 Bird, 86 Bird
Engine: None, 5.7, 5.0 L.O.
Transmission: None, T5, Thm 350
Axle/Gears: 3.23, 02' 3.43 rear disc, ???
I have the same problem with my headlights one is just fine but the other one is barely lit... I know I need a new switch tho. But I was hopin that after your problem was solved I would know what else I might need to do to fix mine
Old Jan 21, 2009 | 04:19 PM
crmmaj9's Avatar
Car: 1990 Chevy Camaro
Engine: 305 TBI
I'm inclined to go with RodRob it sounds like a faulty ground they often work loose or become corroded to the point that they no longer make a good connection. The problem is more prevalent in areas with alot of moisture. CHECK ALL OF YOUR GROUNDS!!! Use the process of elimination and I'm sure you'll find the problem...
Old Feb 3, 2009 | 02:26 PM
Fixed mine and that was the problem so maybe thats yours too good luck and thanks
BRoss99
Aug 10, 2025 05:08 PM
The_Phoenix
Feb 4, 2016 07:10 AM
OLDYELLR
Car Audio
Sep 30, 2015 07:10 PM
Omega
Aug 10, 2015 12:46 PM
