LT1 swap won’t start, need help!!
Old Feb 2, 2009 | 02:23 AM
FlyDoc's Avatar
Car: 92 RS
Engine: 94 LT1 383
Transmission: T56-6 Speed
Axle/Gears: posi, 3.26:1,
After installing the LT1 and fallowing several wiring links hear on third gen, my car will not crank at all by the ignition switch. My car acts like the VATS is prohibiting it from starting when I was having key problems. When doing the swap I removed the stock computer, what do I do with the wires that are part of the dash harness? (In picture) where is the VATS modular mounted on the Camaro. Is there a way to wire it out?
Old Feb 2, 2009 | 03:34 PM
FlyDoc's Avatar
Car: 92 RS
Engine: 94 LT1 383
Re: LT1 swap won’t start, need help!!
OK I have read the VATS on the tech page, with out the stock computer how does this affect the VATS? how can I wire this thing out??
Old Feb 4, 2009 | 02:47 PM
FlyDoc's Avatar
Car: 92 RS
Engine: 94 LT1 383
I have checked the value of my keys and then checked the value at the plug at the base of the callom they are the same. I have bypassed the start enable relay and it will start and die. the stock ECM is not installed how does this effect the vats?
midge54
Sep 2, 2020 07:13 PM
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
sreZ28
Aug 14, 2015 07:48 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
