Need an under-dash source for 40A
Old Jan 8, 2009 | 09:18 PM
3.1EyeCandy's Avatar
Car: 1987 GTA
Transmission: 4L60e
I'm putting in the LS1 ecm tomorrow and the harness I bought has it's own fuses for the ecm - two 20A ignition, and one 20A battery. The two 20A ignition are powered by one wire...meaning it's got 40A worth of pull. Where's the best place to wire this in? Are the extension spots on the back of the fuse panel OK for this? I believe I read they were each rated for upt o 35A...but there are like 3 there for ignition and all on the same piece(s) of metal...
Thanks!
Old Jan 11, 2009 | 12:18 PM
Jono4820's Avatar
Car: 1991 RS
Engine: 350 TBI
Axle/Gears: 3.08 lt. slip
Re: Need an under-dash source for 40A
The best way would be to run two power wires from the batery and switch the IG+ with a relay. This way there is no question that your ecm is properly porwered
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
1Aauto
Sponsored Vendors
Oct 19, 2016 08:50 AM
1Aauto
Sponsored Vendors
Jan 20, 2016 01:01 PM
1Aauto
Sponsored Vendors
Dec 2, 2015 03:53 PM
1Aauto
Sponsored Vendors
Oct 13, 2015 03:06 PM
