car wont start after accident
Old Jan 11, 2009 | 03:18 PM
88 trans am's Avatar
where should i start
Old Jan 11, 2009 | 03:29 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: car wont start after accident
Totally dead, or cranks but won't fire?,also what part of car
is damaged?
Old Jan 11, 2009 | 10:24 PM
recarosp's Avatar
Car: 83 Recaro TA/ 95 TA
Engine: 355 / LT4
Transmission: turbo 350 / 6 speed
Axle/Gears: 373 / not sure think same
there is a fuse up front near the nose not sure what side but it runs along the rail should be hidden some where near the battery
Old Jan 11, 2009 | 11:15 PM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
It sure would help to have some sort of information to start with. It's hard to help you if we don't know anything.
For example, a dent in the door wouldn't cause the car not to start. A rear end collision would probably damage the fuel pump and/or wiring. A front end collision could destroy the battery, pop some fuses or fusible links, you get the idea.
Our cars are not equipped with impact fuel shutoff (GM doesn't value its customers' lives as much as Ford does) so it's not any safety device that's preventing the car from starting.
As pointed out already, the first place to check would be fuses.
If you give us more info on what damage there is to the car and how it's not starting, we can help you a little better.
Lou
BlueIroc-Z
Jun 9, 2019 03:22 AM
Wade787b
Sep 29, 2015 01:15 PM
TheExaminer
Aug 26, 2015 04:59 PM
L98GTA87
Aug 5, 2015 11:02 PM
