Can I make factory V6 tach work with V8?
Old Jan 12, 2009 | 02:34 PM
87_TA's Avatar
Got a bug to start making my 94 v6 4th gen car, thats been reverse retro fitted with early 406 controlled by L98 7730 ecm and t56 that was taken out of my deceases 87 3rd gen. I decided to try and make factory guages work, I have both operating, with speedo being pretty close as far as I can tell so far, will check against gps when weather clears. Tach is factory v6 tach, so it reads 33% to fast, any way I can fix this?
Old Jan 15, 2009 | 09:08 PM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
Re: Can I make factory V6 tach work with V8?
http://www.dakotadigital.com/index.c...rod/prd127.htm
Old Jan 16, 2009 | 11:44 AM
87_TA's Avatar
Thanks,
I spent days searching, guess I was not using right keywords.. I ended up finding a LT1 cluster for $30 in better shape than mine. I will make another post for people, I was able to make all of the guages work in the 94.. Probably useless, but it just made it more authentic I guess and a challenge to figure out. The only problem now is I am getting alot of noise to the factory tach, gonna try wires/cap first, but have to drop K-Member just to change wires. Also searched for a noise filter being I always have some sort of issue with that, can't find that either unless the old GM 70s-80would work, but doubt that.
InfernalVortex
Apr 20, 2021 11:31 AM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
