90-92 camaro fuel gauge
Old Jan 29, 2009 | 03:30 PM
First-Timer's Avatar
hi i picked up this car last summer and dropped a carberated 350 sbc in it and i got it fired up and my fuel guage didnt work. So i began to pull the gas tank out and pull the sending unit and test it. The sending unit checked out good. I Cleaned all connections from the sending unit to the plug in it goes into.
I stuck it back on there and manually operated the float by hand. When i had the float topped out the gas gauge only read about 3/8 of a tank or so. And sometimes when the sending unit is unplugged and i turn the key over the gauge will peg out full. I dont really know what else i can check. Does anyone know anything about the voltage limiter? Or does anyone have a wiring diagram for the fuel gauge? Any help or suggestions would be appreciated.
thanks
jeremy
Old Jan 29, 2009 | 04:35 PM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Re: 90-92 camaro fuel gauge
http://www.austinthirdgen.org/mkport...uges_part5.gif
Hope this helps.
Lou
Old Jan 30, 2009 | 03:21 PM
hey thank you much appreciate it. still open to any other suggestions or some help!
Ghettobird52
Jul 5, 2024 11:18 PM
Frozer!!!
Jan 19, 2024 04:55 PM
rocn7roc
Sep 21, 2021 02:16 PM
justin57
Aug 20, 2015 07:05 PM
R3500
Aug 17, 2015 12:16 PM
