no power to pulldown unit
Old Jan 31, 2009 | 01:50 PM
enswrob's Avatar
Car: 89 Firebird
Engine: 2.8L out of a 89 camaro
Transmission: 5 speed
Axle/Gears: ?
so ive done a bit of searching and not found the fuse for the pull down. im assuming its been cut out. since there are a few wires above the fuse block cut and taped. also. im trying to hook the switch up for the parking break. a tan wire. found a cut harness under the console.. 1 has power keyed on. not sure about the rest. orange gray and i think black. might be a 4th wire there not exactly sure. i just rebuilt the hatch motor with new guides and reinforced pice and new gear nut. adjusted far enough that the hatch locks. i am begining to dis like electrical gremlins.
Old Jan 31, 2009 | 05:41 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Re: no power to pulldown unit
For your model year of Firebird the hatch pull-down fuse is not in the fuse panel. It is in a single fuse holder that was attached to the outside edge of the fuse panel. The hot wire coming from it is red with a white stripe. That fuse holder is slipped onto a dovetail on the outside edge of the panel. It can easily be slipped off, so if it isn't there you'll have to search under the dash near the fuse panel to locate it. It has a 15 amp fuse in it.
Lon
Old Jan 31, 2009 | 05:50 PM
enswrob's Avatar
Car: 89 Firebird
Axle/Gears: ?
ill have to look for the red wire w/white stripe tomarrow. i pulled the fuse panel down earlyer today and didn't see any fuse holders as up in the dash.
Old Feb 1, 2009 | 03:51 PM
enswrob's Avatar
Car: 89 Firebird
Axle/Gears: ?
found the red wire with the white stripe under the dash. as suspected its cut. no inline fuse. guess ill have fun figureing out where the other part of the wire runs from the hatch up to the block. does it run up the drivers side or console area?
Old Feb 1, 2009 | 09:43 PM
lonsal's Avatar
Drivers side I think.
Lon
Vintageracer
Jan 10, 2020 05:33 PM
stalkier
Dec 6, 2015 11:25 PM
formula_novice
Sep 5, 2015 03:58 AM
sailtexas186548
Aug 24, 2015 10:11 PM
ZsTransAm
Aug 11, 2015 07:30 PM
