air select and air divert
Old Feb 8, 2009 | 09:08 PM
I_R_O_C_Z_2_8's Avatar
Car: 1991 Trans Am GTA
Engine: 350 tpi
i got a quick question if the smog pump is not working is the air select and air devert sensor working and does the car need that??
Old Feb 9, 2009 | 02:01 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: air select and air divert
What do you mean by the air pump not working?
The computer has no feedback from the AIR system. It will continue to send the signals to the relays anyway. Yes you can remove it but its illegal on a street car in all 50 states.
Old Feb 9, 2009 | 11:39 PM
Engine: 350 tpi
yeah like the smog pump had no belt or anything so i took it out..and where the rubber tube connects to the air select and air divert thing i took it out too cause inside no wires where connected to it.
Bubbajones_ya
Jul 6, 2024 08:32 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
1Aauto
Sponsored Vendors
Oct 5, 2015 03:14 PM
1Aauto
Sponsored Vendors
Oct 5, 2015 03:13 PM
edoff13
Sep 11, 2015 03:55 AM
