91 350 z28 WONT START
Old Feb 25, 2009 | 03:19 PM
1st91z28's Avatar
ive got a spark after the coil i tested with a spark plug looks weak but im getting no spark pass a new distributor and rotor.. any ideas i was having problems with my ignition not cranking the car over so ive been thinking the switch at the bottom of the steering colum ,but how much spark should i get after the coil? if it helps when i start the ignition doesnt throw the starter out sometimes and im getting the winding noise, maybe ground issue?... thnx for any reply!
Old Feb 26, 2009 | 12:00 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Your spark does sound weak.
However fix the starter problem first because you will need to crank the engine many times while repairing and testing the ignition.
The pinion might not be retracting properly.
Check for damage/worn/replace the starter/parts and fix that first so you won’t damage the flywheel.
Then repost on the spark problem.
Happy Racing!
If People Drove Any Slower They’d Be Going Backwards
How bout those dorks too scared to drive without headlights in the daytime!
Old Jul 19, 2009 | 04:28 PM
1st91z28's Avatar
Re: 91 350 z28 WONT START
DARN ECM!!! go figure
Frozer!!!
Jan 19, 2024 04:55 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Infested
May 22, 2018 11:56 PM
theshackle
Mar 5, 2017 06:37 PM
Burnt.Clutch
Camaros Wanted
Aug 21, 2015 11:11 PM
