Headlights: Driver's Side: Powerless
Old Mar 7, 2009 | 05:19 PM
Justin1989's Avatar
Car: 1989 GTA
Engine: 5.7L TPI 350
Transmission: Automatic
Help me out, I got new motors, both will spin when plugged into the passenger side, but neither will work when plugged into the driver's side. It must have happened recently, because the old refab motors would spin and be stripped, but suddenly the driver's side would not spin. What's the deal? I have a date tonight, try to be quick!
Both HEADLAMPS will work.
Old Mar 7, 2009 | 11:31 PM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Re: Headlights: Driver's Side: Powerless
If one side is working fine but the other isn't, it could be:
a) wiring for the driver side
b) headlight module
Try wiggling the connector on the headlight module (next to the wiper motor).
If you have a test light, you can test the connector on the driver side motor and then the connector on the headlight module. Wiring diagram here: http://www.austinthirdgen.org/mkport...ody_wiring.gif
Hope this helps.
Lou
Old Mar 9, 2009 | 10:41 PM
Justin1989's Avatar
Car: 1989 GTA
It was the headlight controll module by the windsheild wiper.
Old Mar 10, 2009 | 05:40 PM
BigBadLou's Avatar
Engine: TPI
Good to hear. Another problem solved. One down, millions to go.
Lou
Veaceonee
Sep 29, 2016 08:15 PM
AmpleUnicorn88
Brakes
32
Nov 18, 2015 11:02 AM
ZMWojnar
Interior Parts Wanted
Sep 24, 2015 08:34 PM
jerflash
Exterior Parts for Sale
Sep 22, 2015 09:58 AM
abrilnelson89
Sep 17, 2015 10:41 AM
