Identify these parts
Old Mar 14, 2009 | 07:05 PM
Jcase350's Avatar
Car: 90 Camaro Iroc-z
Can anyone identify the parts in the diagram on link below at the bottom of the page? Thanks
https://www.thirdgen.org/vats_passkey_system
Old Mar 14, 2009 | 07:57 PM
rodrob1961's Avatar
Car: 2003 SILVERADO /86 IROC/85 S10
Re: Identify these parts
Exactly what parts are you taling about? The vats is mounted under the dash by the drivers right knee cap. At least it is in my 82 z28.
Old Mar 14, 2009 | 08:02 PM
Jcase350's Avatar
I am trying to get a visual on the starter enable relay and VATS module. If i knew what they look like and exact where they are it would help out a lot.
Old Mar 22, 2009 | 01:29 PM
tony_cogliandro's Avatar
Car: 1990
Axle/Gears: stock
its a vats module. it plugs in and pulls out. it checks the voltage to see if the key you are using has the same resitor in it that the vats module has.
is that what you mean?
Old Mar 22, 2009 | 01:53 PM
Jcase350's Avatar
Yeah thanks...do you know if the other is a VATS relay or start enable relay?
Old Mar 23, 2009 | 09:57 AM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Geez guys, is it really that hard to identify 4 parts? This is a tech board, we're supposed to help.
1 - VATS module
2 - VATS module hold-down bolt
3 - relay hold-down bolt
4 - Starter Enable relay
If you are looking at the Starter Enable relay because you have a starting problem, try this troubleshooting article: http://www.austinthirdgen.org/index.php?pid=38
Hope this helps.
Lou
Old Mar 23, 2009 | 03:16 PM
Jcase350's Avatar
Lou,
Appreciate the help...that's exactly what i needed to know. That article is spot on too. Thanks again.
Casey
LT1Formula
20
Nov 14, 2015 12:02 AM
Linson
Aug 21, 2015 02:12 PM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
1nastygta
Aug 8, 2015 07:38 PM
