Replaced MAF wont start!
Old Mar 16, 2009 | 07:43 PM
xhozst's Avatar
Car: 85 iroc-z tpi 45k mi,,,77 1/2 z28
I bought what must be a refurbished bosch MAF. Installed it as my manual suggested. Started it. Stepped on the gas and it sputtered real real bad and then killed. I tried starting it again and it just ran for like 2secs and died. It's like it just has no gas all of the sudden. I pulled the cord and drove it home after several unsuccessful starts. Put it the old MAF and now it drives like it did before. What is the deal. I had the MAF trouble code since i bought the car. Was it always running off the preprogrammed ECM and when i put the new maf in the timing is bad or what?
Old Mar 17, 2009 | 08:49 PM
xhozst's Avatar
Re: Replaced MAF wont start!
So here's the update. I thought it might be possible the person before me replaced the ecm and changed out the burnoff. But i looked at the ecm and it still has the module attached and wired that i believe commonly denotes it as a 85 tpi. I also checked the numbers on each maf and they were the same. The car smokes badly with the new maf and barely runs. Idles horribly. I pulled the troubles codes and i got 33 and 34 which both seem to denote MAF. I took voltage readings from the connector when unplugged and running. I took them fast as the light was fading and i needed to return the maf soon. So it is possible i screwed up. I also didn't check ground continuity. The chart below shows the results. If you know where i can find what they should be let me know. I ohmed both MAFS out every wire and they seemed to be damn near the same. Never used a scope tho. Thanks,
____BLK&WHT BLK GRN BLU RED
VDC___.05___.05_5.07_.07_14.55
VAC____0____0__10.3__0__31.1 (I think these may be wrong, my reference was battery -)
specialized
Jun 18, 2022 09:26 AM
89GTAOz
May 16, 2020 09:31 AM
NBrehm
Aug 25, 2015 11:49 PM
perZ
Aug 15, 2015 01:17 PM
mizz0313
Aug 12, 2015 06:45 AM
