Taillight wiring ... please help
Old Mar 20, 2009 | 06:47 PM
86T/A.BBC's Avatar
Car: 05 Corvette Z06, 86 T/A Big Block
Engine: 468, 427, I6
Transmission: TH400, 6-speed, TF999
Axle/Gears: 3.42, 5.38
I want to install formula taillights on my 86 T/A but I noticed the hrnesses are different due to number sockets and wires. I really need help with this and have not found any info on it, only T/A lights to a firebird but thats opposite, thanks
Old Mar 21, 2009 | 10:43 AM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Re: Taillight wiring ... please help
Like I mentioned in the PM reply, you'll need to perform a wire change under the dash (on the steering column).
You'll need to find the blue wire going from the brake switch to the turn signal connector (where it might turn white). Cut that wire. Then take the light blue from the brake switch and extend it all the way to the tail lights. That's your brake signal to the brake lights.
That should be all, not much to change.
Hope this helps.
Lou
P.S.: Btw, I just noticed the BBC in your name and also the VH avatar. Rock on!
1992 Trans Am
May 10, 2023 07:19 PM
Caspar
Jun 19, 2016 11:19 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
C409
Sep 1, 2015 03:42 PM
Bryan F
Aug 27, 2015 07:28 AM
