weird speedo problem
Old Mar 22, 2009 | 01:32 PM
akmusclecar's Avatar
Car: 1988 Pontiac Firebird
Engine: 5.0 TBI
Transmission: W/C T5
Axle/Gears: 3.08 Posi
Alright i have a 88 firebird, TBI, WC T-5, And 118,000 miles on the car. Here is the problem. My speedo will work for 20-30 mins. before it starts to act up. In alaska i usually have to have the heater on, then after the heat has been on for a while the speedo will cut out intemittentaly. If i turn the heat off, and turn on the cold air it will start working after a min or two. Also tapping the dash under the speedo will get it to register if its not working. I was leaning towards a loose connection at the dash, but it is the heating of the dash that puzzles me If anyone has ideas of what to check, your insight will be greatly appreciated. - Russ
Old Mar 23, 2009 | 06:11 PM
Engine: 5.0 TBI
Re: weird speedo problem
Bump! Anyone?
Old Mar 26, 2009 | 01:43 AM
zakks92maro's Avatar
i have a speedo prolem too. its not hooked up now, but when i hook it up, i can go about 15 feet then the car will die. and the only way to get it to stop dieing is to pull the speedo cable out of the transmission. i have NO IDEA why!??!
Old Mar 26, 2009 | 07:46 AM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
curious, mechanical or electronical speedo? anything after 91 is electronic, 90 and later was mechanical. Just curious, because i have the same problem but mines mechanical kind of :P hehe
Old Mar 26, 2009 | 09:47 PM
its a 92 so its electornic. theres so much **** wrong with it it wouldnt surprise me if it didnt have the original engine.trans. or computer
Ghettobird52
Jul 5, 2024 11:18 PM
Cleotiz
Jan 6, 2018 08:56 PM
Eric2ndGen
Nov 5, 2015 01:51 PM
CORV3TT3
Aug 23, 2015 11:26 AM
sreZ28
Aug 14, 2015 07:48 PM
