A few silly electrical questions... 1991 rs
Old Mar 23, 2009 | 02:38 PM
Guest
Guest
Posts: n/a
Hello, first post to these boards. I just had a couple silly little questions I ran into last night while replacing some fuses on a 1991 camaro rs. First, one of the fuse sockets won't hold a fuse, I'm guessing I can just disconnect the battery and disconnect it out of there and fix it with a knife or something to get the socket tightened up. Anyone have any input on this?
And most importantly... I went looking for the turn signal flasher relay because mine aren't flashing... I found it on the right side inside the lower dash next to the steering wheel. Problem is... it's not there!! Anyone know what a suitable replacement would be for this so I can pick it up on my way home from work because right now the turn signal lights stay on steady. Thanks!
Old Mar 23, 2009 | 03:09 PM
Wadebryant's Avatar
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
Re: A few silly electrical questions... 1991 rs
Welcome to TGO.
Some of the fuse positions are vacant and will not take or need a fuse. Make sure that the metal female recepticles are present in the fuse block.
The flasher is available at most parts stores.
Good luck
Linson
Oct 24, 2025 02:00 PM
SRKLEGIN
Oct 29, 2015 06:38 PM
ZekeThorpe
Theoretical and Street Racing
35
Oct 7, 2015 07:30 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
lanceflame44
Sep 25, 2015 12:28 PM
