Need help with Fuel Pump wiring
Old Mar 25, 2009 | 11:28 AM
JTNKTZ's Avatar
Car: 1991 Camaro RS/1989 Vert RS
Engine: 355/350
Transmission: T-5/T-5
Axle/Gears: BW9bolt3.45posi/3.23 Posi
Well I decided today I am going to figure out what is wrong with my fuel pump and it's wiring. Right now I have a 12v constant on a switch that leads to a splice in the orange wire on the fuel pump relay. The orange wire does not have a 12v constant alone. Where can I trace this back? The fuse by the battery is not blown so that is not it. Where can I find the beginning of this orange wire?
Old Mar 25, 2009 | 11:58 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: Need help with Fuel Pump wiring
All the wires from the gas tank should run under the dash, on the driver's side. I had to do the same thing to my '91 RS LO3, I left it manual switch for 2 years. Screw a relay. If you hide the switch, it's good anti-theft.
Old Mar 25, 2009 | 12:56 PM
JTNKTZ's Avatar
Engine: 355/350
My VATS is good enough. I could barely break into my own car with out the resistor in the key (fell out). I really just want to know where this damn orange wire runs too!!!
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
Infested
May 22, 2018 11:56 PM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
