Car keeps running w/out key TPI to CARB
Old Mar 25, 2009 | 06:23 PM
383fbod's Avatar
Car: 88 IROC-Z
Engine: 383
Axle/Gears: 4th gen 3.42posi
I went from an 88' 5.0 TPI auto to a 383 carbed with a T56 and now
I cant find how to make my IGN hot unless I hook up the orange wire(on a plug with the thick yellow one) under the center console to my black reverse light wire (on the plug with neutral safty wires), but it just keeps running when I turn the key off. If I kill the master power via 150a breaker in +batt. circut, engine goes off. my alt wires are hooked up as follows: brown to harness on driver side fire wall (stock location.) tan/white unhooked ,thicker red to starter sol., Bottom thick red wire to batt. I have heard I need a 300ohm resistor on the brown wire will that fix this prob?
Old Mar 25, 2009 | 07:06 PM
383fbod's Avatar
Car: 88 IROC-Z
Engine: 383
Re: Car keeps running w/out key TPI to CARB
I also just read that a diode in the alt. exciter wire will fix this
any input would be great
Old Mar 26, 2009 | 07:06 PM
383fbod's Avatar
Car: 88 IROC-Z
Engine: 383
I also dropped my steering collumn and none of my IGN switch wires have power
How do I get power to IGN switch?
Fuse block?
midge54
Dec 27, 2019 04:14 PM
theshackle
Mar 5, 2017 06:37 PM
86IROC112
Aug 17, 2015 02:00 PM
Kaweh
Aug 9, 2015 02:54 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
