Power locks - wiring experts chime in!
Old Mar 26, 2009 | 06:34 PM
84redta's Avatar
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
Is there an absolute need for a relay in our wiring? I'm wiring in a keyless entry module from a 93-95 intomy 88 and it seems like if I take the relay out, it would resolvey headache of figuring out the whole thing. Someone give me a valid reason (with explanation) of why it's needed. Thanks
Jon
Old Mar 26, 2009 | 07:14 PM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Re: Power locks - wiring experts chime in!
The relay is needed to amplify the current. Most alarms can handle 0.5A or maybe 1A for un/locking the doors whereas our door lock motors draw anywhere from 10A up.
That's why you need to use relays, to use the 0.5A to operate the relay which then sends the desired 10A to the door lock motors.
Otherwise you would burn up the alarm on the first dis/arm operation.
Hope this helps.
Lou
Old Mar 26, 2009 | 07:31 PM
84redta's Avatar
This is using the factory 93-95 keyless entry module, i assumed, looking at both wiring schematics that it did that very thing with amplification of amperage within the module. Let me find the two schematics, not that it'll prove amperage, but just for quick referance to what i'm speaking about.
Old Mar 26, 2009 | 07:32 PM
84redta's Avatar
Third gen power door locks:
http://www.austinthirdgen.org/mkport...door_locks.jpg
Early fourth gen keyless entry:
http://shbox.com/1/keyless_schematic.jpg
Thanks again for your help Lou!
Jon
Old Mar 26, 2009 | 07:34 PM
BigBadLou's Avatar
Engine: TPI
Sorry, my answer was a little generic to all alarm systems but it applies to the factory remote entry module as well. Such digital modules (whether GM or aftermarket) rarely put relays on the digital board. Instead, they relay on external parts.
If you have the schematic, that'd help a little.
Lou
Old Mar 26, 2009 | 07:37 PM
Jeff91RS's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: World Class T-5
Axle/Gears: 3.27 9-Bolt LSD
the 93-94 uses reverse polarity locks and the 88 uses positive pulse.
http://www.the12volt.com/installbay/...etail/485.html 93-93
http://www.the12volt.com/installbay/...etail/483.html 88-90
so you are going to have to use relays, unless the factoy keyless modual puts out a pulse and the relays are used for the reverse polarity syste.
BRoss99
Aug 10, 2025 05:08 PM
Ghettobird52
Jul 5, 2024 11:18 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
stalkier
Aug 13, 2015 12:59 PM
