Side Marker Lights Shorting Out
Old Mar 26, 2009 | 10:59 PM
Shadyredeyes's Avatar
Car: 1987 Camaro Iroc Z28
Engine: 350 S/B
Transmission: 700 R4
Axle/Gears: 2.43 Gear Ratio
On my 1988 Camaro SC my sidemarker lights keep going out along with my passenger side front blinker. Bulbs are all new and work until you turn blinker on. Once this happens both sidemarker lights and passenger side blinker go out again. When I bought the car the headlights did not work properly. Low beam works but when switched to high beam passenger side low and high beam go out. I found a ground wire and attatched it to high beam on passenger side and now my headlights work with the exception of both lights on passenger side come on when high beams are on. I'm no good when it comes to wiring so any input would be greatly appreciated.
Old Mar 30, 2009 | 07:02 PM
Engine: 350 S/B
Re: Side Marker Lights Shorting Out
Ok now that I have good bulbs in place the passenger side front turn signal does not come on with headlights. Side marker on drivers side does not work either. All other lights work properly.
ziggy89
Exterior Parts Wanted
Sep 10, 2015 08:44 AM
Fronzizzle
Aug 17, 2015 02:52 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Omega
Aug 10, 2015 12:46 PM
NBrehm
Exterior Parts for Sale
Aug 5, 2015 08:19 PM
