Tach not reading right RPM?
Old Apr 2, 2009 | 06:55 PM
chevman24's Avatar
Car: 88 and 02 Camaro's
Engine: L96 (LS) and LS-1
Transmission: auto, 6 speed
Axle/Gears: 3.42 gears for both
I switched to a carbed 350 from the tbi 305 engine and now my tach reads 750 rpms when my timing light reads 500? What do i need to do to fix this issue?
Old Apr 2, 2009 | 07:17 PM
zz4IROC's Avatar
Car: 1988 iroc
Engine: 350 forged crank, pistons, 11.5:1
Transmission: t-5
Axle/Gears: 10 bolt 3.73
Re: Tach not reading right RPM?
i switched from tpi 305 to tpi 350. 1000+ off at high rpm. 250 off at idle. put in an autometer
Old Apr 2, 2009 | 07:30 PM
RITTER's Avatar
Car: 1983 Buick Regal
Engine: 355
Transmission: TH350
Axle/Gears: 4.11
Stock tachometers tend to go bad anyway. I would replace the entire tach.
Old Apr 2, 2009 | 07:50 PM
chevman24's Avatar
Ill just use the auto meter i have laying around. I just wanted to keep the stock look, oh well.
thanks
Old Apr 2, 2009 | 10:14 PM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
No need to rice up your car with extra tachs, you can just fix the old one. There are multiple threads on the topic in this section, just search.
Lou
eightsixseven
Dec 16, 2024 01:50 PM
Armored91Camaro
Aug 25, 2015 12:01 PM
Regal105
Aug 23, 2015 03:45 PM
mustangman65_79
Aug 7, 2015 09:41 PM
