Electronic Gurus and Engeneers Inside Please: Question about wiring polarity switches
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
I have 2 questions. First question; its a bit complicated but I'll try to explain as clearly and simply as possible. I have a project and need some assistance in wiring a switch. The situation is that I have a window motor and a regular window switch and as we know, the switch has has 4 wires on it. One positive, one negative and the other 2 go to the motor. The switch itself decides which of the other 2 is pos or neg. What I want to do is keep the motor at a certain polarity UNTIL I flip a switch (rocker switch). For example, if I were using it on a window. I would want the window to stay down all the time, until I flipped this switch, and then it would roll up and stay up until I flipped the switch back and it would automatically roll back down. Is there a way to do this? I think I've heard of some mechanisms (door locks?) being done this way on certain cars... Maybe nitrous bottle openers work this way? I don't mind if I have to use relays and resistors or whatever is needed.
Another quick question is about how the rear defrost works on our cars, I know there is a timer, but I'm not sure if its a timer module or if its the switch itself. Can anyone tell me which one? I tried doing a search and some posts say its the switch and others say its a module... Thanks again
Car: 1987 Trans Am
Re: Electronic Gurus and Engeneers Inside Please: Question about wiring polarity swit
never mind about the first question, I had a few automatic window switches for alarm systems lying around and that will work perfectly.
Can anyone answer my second question? is there a second module/timer for the rear defrost?
Car: 1971 GM Holden, HQ GTS Monaro Coupe
Engine: Gen I 350 Chev soon to have TPI
Transmission: TH400
Axle/Gears: Going to be a 3.55
Maybe something like this??
http://www.jaycar.com.au/productView...r&form=KEYWORD
or this
or this
I'm sure you could find an electronics dealer or shop that would have something similar.
or this
or this
Engine: '85 Monte SS L69 305
Transmission: TH 200-4R
The rear defrost switch has the timer electronics built into the switch afaik.
Car: 1987 Trans Am
Thanks for the help guys. This is mainly to keep a turbo oil pump running after the car is shut off. I think I will go for an electric timer. I was just trying to see if it was possible with "junkyards" parts...
Transmission: TH400
I may think you'd may be better off using a Turbo Timer as they generally also have a temperature input so they won't shut down the oil supply (turn the car off) if the turbo is still to hot.
Again, I think you can buy these as kits or most auto stores should have something similar if that's what you are trying to achieve.
Col.
Col.
Car: 1987 Trans Am
yeah, I still have more research to do in that area...of timers and such. I just want to keep the oil circulating a bit more so it doesn't build up in the turbo (its remote rear mount) and escape through the seals....and smoke on startup.
