SOME SENSOR??
Old Apr 10, 2009 | 01:39 PM
BloodyBlueBird's Avatar
Car: 86' Firebird
Engine: 350 c.i. swap
Transmission: G-Force T5
SOME SENSOR??
Hey guys, is there some sensor that would prohibit a spark from being produced through the spark plug wires?? because I'm not getting any spark at all. Even when I have changed everything with my spare/old distributor setup. It may be possible that some how both pickup coils are gone... but that seems way too unlikely.
Old Apr 10, 2009 | 01:41 PM
Car: 86' Firebird
Re: SOME SENSOR??
oh, and aside from the ECM. I tore out the computer after the swap a year ago.
Old Apr 10, 2009 | 06:29 PM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Re: SOME SENSOR??
Standard procedure:
- turn key on, check voltage on coil (pink wire)
- check voltage on white wire (if 0, bad coil/connector)
- ground white wire - if no spark, bad coil
If spark - bad distributor or plug wires.
Hope this helps.
Lou
HoosierinWA
Oct 7, 2015 10:15 AM
aaron7
Sep 30, 2015 09:15 AM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
dusterbd
Sep 29, 2015 08:40 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
