continuous power?
Old Apr 10, 2009 | 10:05 PM
ditchbangr's Avatar
Car: One of 5
Engine: LB9
continuous power?
I am working on a 85 iroc and pulled it apart last fall and trying to figure out what I need and don't need. I am switching from a computerized quadrajet to a carb's 406. I have power going to the starter, the small wire that energizes the starter and the other large wire that cranks over the engine.
I am just wondering where does the car get the contiuous power for dome light, radio etc etc when the ignition is off? Basically it must be a larger wire that carries power to the wiring harness, like a 10 or 12 ga? Thanks for any help.
Old Apr 11, 2009 | 09:15 AM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Re: continuous power?
All the power comes from extra wires with fusible links that are connected to the starter solenoid.
If those fusible links are broken, they might give you crazy electrical nightmares.
Hope this helps.
Lou
neilb
Oct 4, 2018 12:36 AM
mddaniel
Sep 8, 2015 05:16 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
sailtexas186548
Aug 24, 2015 10:11 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
