DASH ELECTRICAL NIGHTMARE
Car: 85 Camaro
Engine: forged 383 11:1
Transmission: T56 TDP STAGE 2
Axle/Gears: 99 ws6 3.42 posi rear
Ok i installed some cheap ebay h4 headlights, cut the harnes and swapped the wires around so it would be wired correctly for the h4 bulb. After about 3 days the right half of the dash began acting weird. The rpm gauge oil pressure gauge and voltage gauges just lose power and then the right turn signal indicator turns on. Sometimes it turns back on then it turns off.
This problem DOES NOT happen when the headlights are turned off. Only when the driving lights, or full headlights are on-high or low doesnt matter.
Earlier today I wired the headlight harness back to normal and put new OEM headlights in and its still doing it.
